Whats everyones thoughts on adding an option so you can limit the rpm that cold advance is active under?
Kind of like idle advance, but specifically for cold advance, so it would easily bump warmup idle cells (say < 1200rpm) without worrying about the rest of the table seeing the same timing increase.
Cold advance rpm limit
'88 BMW E30 M20B25 GT3582r, MS2, Mitsubishi GTO wasted spark coils, 630cc injectors, launch control
