traction control using knock function. ms2
Posted: Sat Aug 12, 2017 10:07 pm
I've made some good progress on a teensy3.2 board for a transmission controller(4r70w). Im currently reading vehicle speed from the trans mounted VSS. I could install a sensor to pick up front wheel speed and sort out a % of slip between the 2 wheels. The teensy3.2 aslo has a DAC output that could be driven based on the ampiltude of % error. The only function in MS2 for progressive timing retard is knock. Feeding the DAC output into adc7 or 6 may do the trick. Looks like analog over CAN isn't an option.
Any ideas on this one?
Thanks Ryan
Thanks Ryan
