MS2/Extra-release-3.4.2 BUG: AC indicator stays on
(Runs on MS2 and Microsquirt)
Postby jsdevel » Mon Oct 23, 2017 9:05 am
I've found what I believe to be a bug in this firmware version. I have AC idle up working properly i.e. the compressor cuts out when min rpm threshold is reached. I've noticed that the AC indicator light in TS stays on.
The relevant code in the idle_ac_idleup function is this:
if (outpc.rpm < flash12.ac_idleup_min_rpm) {
DISABLE_INTERRUPTS;
*port_ac_out &= ~pin_ac_out;
ENABLE_INTERRUPTS;
ac_time_since_last_on = 0;
return;
I noticed elsewhere in the idle_ac_idleup function how the indicator light was being switched off, so I updated the above code block as follows and now the AC indicator light cuts out when min rpm threshold has been reached:
DISABLE_INTERRUPTS;
ENABLE_INTERRUPTS;
outpc.status3 &= ~STATUS3_ACOUT;
return;
jsdevel
Re: MS2/Extra-release-3.4.2 BUG: AC indicator stays on
Postby Blown88GT » Sun Dec 03, 2017 11:15 am
What is the status of this?
1988 Mustang GT, 57k miles, Orig. Owner
ProCharger 600B I/C, 12psi, FRPP Hdrs, Flwmstr F2, 3G Alt, Mk8 Fan & DCC, 3.55's, Prog Sprng, Subfrms, UCA, LCA, FCA, Tokico 5-way, CSA 16x8, Bridgestone RE760 225/50R16, Crane HI-6, Kirban FPR, MS2, DIYPNPF60, LC2, C&L76mm blo-thru MAF, 30lb FRPP
Blown88GT
