CAN gpio ADC rate?
(Runs on MS2 and Microsquirt)
ol boy
CAN gpio ADC rate?
Post by ol boy »
At what rate does the ms2 unit request the adc count from the expansion board?
Re: CAN gpio ADC rate?
Post by jsmcortina »
Every 10ms.
ol boy
Post by ol boy »
Im pulling baro data from an i2c sparkfun widget and then scaling to 10bit adc inside a teensy3.2. Is it possible to slow down the request rate to 1hz? Im planning to only sample the baro sensor once every 200 feet as i travel down the road. In ms2, what function would need adc over CAN at 100hz?
Thanks Ryan
The CAN polling is called from main(). You can alter the code to slow it down.
ol boy
Post by ol boy »
It took some bit of screwing around but i was able to get cygwin installed, loaded the tools and ran a "make release". I'll give it ago this weekend. How would one remove the lag factor for baro from using the same lag as clt,mat,battery? I cant seem to find where and how the lags are calculated.
Thanks Ryan
