Renix 44-2-2 and wasted spark
Can someone fix the problem with renix mode (44-2-2) and wasted spark? running single coil works fine, but when switching to WS, RPM goes to 0
\\ red-racing
\\ red-racing
Re: Renix 44-2-2 and wasted spark
Renix wheel wont be able to run Wasted Spark, because renix wheel only has 180 degrees of resolution
I see, It not possible to make know which channel to fire.
but it is possible with cam sensor?
Cam sensor will give you 720 degrees allowing you to run fully sequential, but this feature is not avaliable for renix wheels.red-racing wrote:I see, It not possible to make know which channel to fire.
If you are running a renault, find a late gen clio toothed wheel. It bolts on without any mods in replacement of the renix wheel and you can use the same VR sensor.
I run volvo B230 engine. But same thing applies there. 60-2 bosch wheel bolts directly on, same sensor
yes it is working ! with 44-2-2 and 66-2-2-2... just add cam sensor. (it is explain on the microsquirt manual)
"Typically Renault installs utilise a crank sensor only and output to a single coil and distributor. Wasted spark or coil-on-plug require a single tooth on the cam and a cam sensor. The cam pulse needs to occur before the missing tooth region that precedes TDC#1 firing."
bye
bye
Renault Clio 16s 1992__________Renault 5 gt turbo 1985__________Alpine GTA V6
1980cc 4cyl, single coil , high Z___1393cc 4cyl wasted coil, low Z ___2800cc, 6cyl
206 hp @ 7100 tr/min__________180hp @ 6000tr/min____________180ch@6300tr/min
Can you post a copy of your tune file and a composite log of an attempted start? I'd like to check if you're just not picking up the cam signal.red-racing wrote:I run volvo B230 engine. But same thing applies there. 60-2 bosch wheel bolts directly on, same sensor
I run without cam signal. just 60-2 on crank (original)
Rennix mode requires a cam signal for wasted spark. Without the cam signal, the pattern repeats itself every ignition event, and so you have no cylinder identification.red-racing wrote:I run without cam signal. just 60-2 on crank (original)
