Lag on throttle application
A general forum and a place for initial or prospective users. See MSExtra Documentation
Click here to enter
Contact a Forum Administrator
Postby beachbuggy61 » Wed Jun 20, 2012 1:35 am
Hello experienced tuners!
I've got my bug running really well at the moment but I still have a small issue when I 'blip' the throttle on downshifts.
There seems to be a hesitation which can mean on a quick shift, it doesn't rev at all!
I've done a datalog (attached) of throttle application when the car is stationery, trying to imitate the problem. I've also attached the current tune.
Could it be something in the acceleration wizard settings?
Other than this the car is running really well. Love the flexibilty that the bluetooth gives!
Many thanks, Marc.
2012-06-20_17.56.56.msl
(336.5 KiB) Downloaded 27 times
2012-06-20_17.59.48_E85.msq
(58 KiB) Downloaded 23 times
1968 VW Type 1 Baja 1915, Borg Warner K16 Turbo, EDIS, Quad throttle body injection, MS2
beachbuggy61
Re: Lag on throttle application
Postby Matt Cramer » Wed Jun 20, 2012 5:22 am
Yes, probably an AE issue - but I think it may be too much rather than too little.
Postby beachbuggy61 » Wed Jun 20, 2012 9:54 pm
Thanks Matt, I was thinking that it might be too much or too little.
Having seen what my settings are on the msq file, do you have any advice on perhaps what it should be??
In the old days I'd put a smaller pump jet in it! How do I best do that now?
Thanks in advance, Marc.
beachbuggy61
Postby Matt Cramer » Thu Jun 21, 2012 6:01 am
Postby beachbuggy61 » Thu Jun 21, 2012 4:41 pm
Thanks Matt, I'll do some reading.
I just have to tramslate it to TunerStudio, but I guess the theories are the same.
Cheers, Marc
beachbuggy61
Postby beachbuggy61 » Sun Jul 15, 2012 6:24 pm
Did the reading necessary and now I've reset with a change to the way the EA works.
Instead of 100% TPS, I've now got 60% TPS and 40% MAP and it runs perfectly. Blip the throttle any time and it responds.
Guess I should've read the instructions more completely from the start!
Note to self...
Thanks Marc.
beachbuggy61
Users browsing this forum: Bing [Bot], jesse408 and 4 guests
