Does BIP373 need Pullup to run a Bosch Coil?
Does the BIP373 need a pullup to power a Bosch Coil?
http://www.german-spob.de/start.php?nam ... el_id=5867
http://global.rakuten.com/en/store/emuz ... -150-0480/
Re: Does BIP373 need Pullup to run a Bosch Coil?
Do you have any wiring diagrams that show the OEM install of that coil? I'm not familiar with it.
I do not have the original wiring...however, I know that it is controlled directly from the Original ECU.
By the way, what could be the negative side effect to have a Pull-up on a BIP373(to be used as a coil ignitor)?
If the coil is a high-current type, you will make the spark weaker.efims wrote:By the way, what could be the negative side effect to have a Pull-up on a BIP373(to be used as a coil ignitor)?
You really need to find the coil pinout (and pin names) before you try to wire it up.
How can I do this??
There is nothing written on the coil pins(terminals)
High Current Coil...how can I identify this?
I measured the resistance of the coil
7.5K ohm secondary coil
0.6 Ohm Primary coil
How can I do this??
Well - you've identified the pins. The 0.6 Ohm pins are the primary side; one pin receives switched & fused +12v from the fuel pump relay, the other is grounded through the BIP373. The other pins are your secondaries, going to the spark plugs.
Thanks..
But still not sure if I need a Pullup Resistor for the BIP373
For high current coils, you do NOT use a pull-up resistor. The only time you use a pull-up is with a logic coil, and then the resistor is between the BIP and the coil's trigger pin.
"then the resistor is between the BIP and the coil's trigger pin"...this is the 330R from MS CPU chip to BIP373?
