BMW m30 3.5 turbo help needed
Hi people I have built a BMW e34 m535 turbo
And I'm trying to y
Use Megasquirt and spark to run if remade the crank pully to run the correct trigger wheel but I'm now ready to upload a base map to tune from but I'm struggling to find a base map
When I used Megasquirt on my chevette I found a webpage with a huge archive listing of base maps but I can't find said webpage
Any help would be much appreciated
And I'm trying to y
Re: BMW m30 3.5 turbo help needed
ms1, ms2 or ms3? what are you doing for ignition and injector size?
Ms2 v3
Edis 6 and wasted spark with 550cc
are you using a idle control valve
You don't need a "base map".
Get all your settings correct, and the fuel/ignition tables that ship with the firmware will be fine to get you up and running.
Wide band O2 sensor?
You will need one to tune it.
I also started from scratch and car has been on circuit in the meanwhile. Take the time and you can map it all
