MSPNP2 Foxbody Help
MSPNP2 Foxbody Help
Hello everyone,
I recently completed my engine build and am having some trouble with my megasquirt. I can get the engine to run and idle but I cannot get the timing on the crank to match what the mega is commanding. When I try to advance the distributor to get my timing marks set the engine revs way up to like 3000 rpms. Can anyone help??
Re: MSPNP2 Foxbody Help
You'll want to adjust the distributor so that you can get the timing in TunerStudio to match your real timing with a trigger angle between 0 and 15. Larger trigger angles will create advance problems.
I have the fixed timing in my Mega at 12 degrees. Trigger angle of 10. When I crank the dizzy to match the 12 degrees fixed from the mega it still idles around 1700.
In that case, I'll need more information:
Here it is. Basically just the base map for my car with the few timing tweaks.
I will also need the data log of it revving to 3000 RPM.
Just started it and let it run a few minutes. This is what I got.
Try reducing the PWM Idle Duty at those temperatures.
Also, once you have the timing confirmed with a timing light, turn off the Fixed Angle setting; that's mostly for checking your timing.
