I have a buddy I'm helping set up with an MS-based ignition-only solution for LS coils on his V8. In order to simplify things for him we were going to put the sensors in the same location as a stock LS 58x plus 1x cam. Best I can figure, when the engine is a TDC #1, the sensor should be pointed at the rising edge of the 13th tooth after the gap, or at 78* BTDC the sensor should be at the second missing tooth?
For the cam sensor, the rising edge of the half-moon should be passing the sensor when the fifth cylinder in the firing order (#6) is at TDC.
Is this correct?
I'm swaying him towards an MS3Pro but he *might* end up going with a caveman solution like the MSD 6014 so I want to make sure I've got him set up for either option.
LS 58x Phasing
Re: LS 58x Phasing
Isn't 40 BTDC what is recommended for a V-8 in the manual? That's what I would shoot for, although mine is 58* (by legacy) and working fine. With such a wide acceptable range (40, 78, 58, etc.), whether that is first or second tooth, or rising/falling edge of tooth, is of no concern... especially if you go for the 40 BTDC.
PS: the CMP signal is even less fussy, using "half-moon". You can specify nearly everything there in TS
Re: LS 58x Phasing
I usually just take maximum timing and add ten degrees, unless that puts the missing tooth in the middle of a lull during cranking that can cause issues. I'm specifically asking here where the factory LS motors that run 58x +1x cam are phased so I can copy it on his install to give him maximum flexibility.
Re: LS 58x Phasing
When setting mine up, I read it was supposed to be the 14 tooth or like 84*. Testing with a light and a pointer I needed 78* to match timing, and with the 4x wheel on tdc one of the teeth is in the middle of the tooth, so it's just reading poll. I believe the same with the 1x cam insetup too. It's in the middle and is just needed for phasing, not really and edge
Re: LS 58x Phasing
Alright, sounds like I'm on the right track then. I think the 78/84 kerfluffle might be because some guys are counting the second missing tooth as the first tooth instead of the first tooth after the gap as being the first tooth!
