Ford Cam Sensor Terminals
Click here to enter
Contact a Forum Administrator
Postby Rick Finsta » Thu Mar 16, 2017 2:07 pm
I'm going to be running a Ford cam synchronizer with the VR sensor and two-pin connector. I can't for the life of me figure out what series terminals cam with the pigtail I've got.
Any ideas?
Here's a link to the connector type:
http://www.bmotorsports.com/shop/produc ... ts_id/1091
Rick Finsta
Re: Ford Cam Sensor Terminals
Postby dontz125 » Fri Mar 17, 2017 6:35 am
That's a Furakawa RFW-series connector. Corsa Technic has them here, as well as spare terminals.
Tell Alex, Don from Canada says hi! 8)
dontz125
Postby Rick Finsta » Fri Mar 17, 2017 11:10 am
Much obliged! I tried a Ford and Chrysler dealership and it seems as though they don't do anything except swap entire harness sections these days... actually I think it's been like that for awhile now.
Rick Finsta
Postby Rick Finsta » Sun Mar 19, 2017 4:22 pm
Corsa Technic turns out is local - I had them next day. They weren't exactly correct as this housing doesn't use the little blades but a few seconds on the grinder and they fit perfectly. I'm going to be running VR sensors for the front and rear wheel speeds as well so I'll make good use of these things. The Ford sensors are really quite inexpensive and are very robust.
Rick Finsta
Postby dontz125 » Sun Mar 19, 2017 4:43 pm
How very odd - that sure LOOKS like an RFW in the link you put up ... Oh, well - you're all set; glad you got it so fast!
dontz125
Postby Rick Finsta » Mon Mar 20, 2017 6:46 am
I'm guessing the connector is a Chicom ripoff! The OEM Ford unit I've got absolutely has the grooves for those tabs, and this one looks like they were there, but when you try to insert the terminals it's like they don't go all the way through or something. I test fit one of the terminals in the actual Ford connector housing and it fit perfectly. Thanks again for the pointer!
Rick Finsta
Postby ashford » Mon Mar 20, 2017 7:11 am
Rick Finsta wrote:Much obliged! I tried a Ford and Chrysler dealership and it seems as though they don't do anything except swap entire harness sections these days... actually I think it's been like that for awhile now.
it seems they are too lazy to pinpoint fix things. here is the ford catalog
https://www.fordparts.com/FileUploads/C ... 202016.pdf
ashford
Postby Rick Finsta » Mon Mar 20, 2017 6:22 pm
I'm not sure I know of a dealership that does anything except replace entire subharnesses these days.
Rick Finsta
Users browsing this forum: No registered users and 4 guests
