msq for triumph parallel twin
hello, thanks for the add. I have turbocharged a 1958 Triumph twin. The microsquirt is a fuel only system that runs with vr1- as tach signal. from a pazon digital ignition. would like information on the basic msq setting that should be used? MSQ as is.
Re: msq for triumph parallel twin
Hello,
Check the manuals top left, Quick links:....
If your running a turbo the max map limit needs a bit more ?
You can choose a 16x16 fuel map instead of 12x12.
When using a low Z injector pwm style Thershold time needs to be less.
This are the things I noticed, check it for yourself and verify whit the manuals.
Thank you for the reply. I am new to EFI and the learning curve is huge. Will let you know what come of the changes after we test it. need to studie each one of the sections before moving foward.
thanks again for the tips,
5 Points
5 Points
You're also required to post pictures of that bike:)
http://www.buildpics.org/
here is a link to the bike @Bonneville Speed Week 2017 just 5 days ago.
https://scontent.fapa1-2.fna.fbcdn.net/ ... e=5A165779
Nice bike, like it.
Something to read, about ignition control on triumph:
http://www.msextra.com/forums/viewtopic ... it=triumph
