Looks like the standard Spartan2 is unavailable but the Spartan2 LB is.
https://www.14point7.com/products/spart ... -lean-burn
Measures O2 from 0.1% to 21%. Car exhaust is normally from 0% to 5ish%. Anyone running one of these yet?
Ryan
Spartan2 Lean Burn...?
Re: Spartan2 Lean Burn...?
I have spartan2 in stock if you need one quickly.
I dont think it's really useful to use a lean burn sensor on a gazoline engine...
I think they usually use it in the diesel world.
