I snagged a few injectors on ebay for a smokin good deal. However, I coudn't find the flow data before I figured I better snag them at the buy it now price. I have a set of 0 280 156 029 (blue with other p/n 1L2E-B5A) and a set of 0 280 155 734 (grey with other p/n 97JF-BA). Does anyone know the flow on these? I think the 155 734 are 24 lb/hr at 3bar (http://64.233.167.104/search?q=cache:2h ... 5734&hl=en). I can't however find anything on the 029s.
I'm hoping the blue ones are around a 40 lb/hr injector. If not, I'll have 6 of the 155 734 injectors for sale 15 of the 156 029 injectors for sale or trade for the Ford 39 lb/hr injectors (0 280 156 127) or some other high imp. solution. I do prefer these EV6 style injectors for their size though....
Thanks for any info!
Levi
Anybody know the flowrate of these injectors?
Call Ford to confirm, but...
This forum thread says that Bosch number 0280156029 is for a Mustang Cobra:
http://66.102.7.104/search?q=cache:NANL ... 7%22&hl=en
And it also says the Ford number is 2R3V-B5A.
(When googling Bosch numbers, sometimes omitting the first "0" helps...)
This site says more:
http://66.102.7.104/search?q=cache:XwFM ... A%22&hl=en
"2003 Ford Mustang Cobra: 39lb EV6/USCAR injectors
Motorcraft CM-5026, Ford 2R3V-B5A"
And this PDF also says it's Ford:
http://www.kemparts.com/scripts/BG-120-3.pdf
"142-2016
FUEL INJECTOR - MPI
Ford (2R3Z-9F593BA,
CM5026)
Ford ...............................2003"
So...call Ford
Last, I believe Ford rates their injectors at 2.7 bar, not 3.0 like most.
PS With your screen name, shouldn't you be skiing, not MS'ing? ;-)
"142-2016
FUEL INJECTOR - MPI
Ford (2R3Z-9F593BA,
CM5026)
So...call Ford
I think you might have gotten the one that I'm going to get if these other two sets don't work in your search. The ones I have are the 1L2E-B5A and the 97JF-BA. All the ones in your search are the 2R3V-B5A.
Thanks for looking around though!
Levi
BTW.......I'm MSing a snowmobile, and yep, I can't wait to be out there!
Levi
