GM IAC PROBLEMS UPDATED
A general forum and a place for initial or prospective users. See MSExtra Documentation
Click here to enter
Contact a Forum Administrator
Postby Lordprimate » Fri Dec 09, 2005 6:57 pm
Spec's in Sig.
1.9l twincam NA mota.
All stock saturn ( GM ) sensors/valve.
The v3 pcb is jumpered for IAC use according to the assembly guide.
First Question!
On the Relayboard, is this correct?
S1 = 1A ("A" = "+" positive)
S2 = 1B ("B" = "-" negative)
S3 = 2A ( " " " " )
S4 = 2B ( " " " " )
more less do the A and B signify Pos, Neg....?
ok moving on
My IAC valve...
O-ringed type
Infinate resistance between the Middle 2 pins...
The day I got my relayboard/wireharness/MS2blah blah blah....
I put everything(MS2/harness/RB/GMIAC"in a TB"/CLT/MAT) on my desk, connected everything... Hooked up my Lamda power supply... Bench tested my IAC... Always on And No Heat...
for the IAC valve I have the Saturn Wireing Scematix... (lookn now as i type, to copy correctly)
IAC A HI --------- Light blue wire / White trace
IAC A LOW ------- Light blue wire / Black trace
IAC B HI --------- Light green wire / White trace
IAC B LOW ------- Light green wire / Black trace
With that Blue would be coil 1 , green would be coil 2
I wired
A HI ---- S1
A LOW -- S2
B HI ---- S3
B LOW -- S4
Tired..
I have contacted a friend that is going to come over and turn the key for me.
I will be using a spare throttle body and SAME model IACV "but different unit", to phically watch IACV movement.
While doing so I will note Step Time and test to see how small I can to with out missing steps. When I have proper "Visual" function of the valve.
And
Set the Start Step more accuratly...
Lordprimate
Postby Lordprimate » Sat Dec 10, 2005 3:34 pm
Lordprimate
Postby Lordprimate » Sat Dec 10, 2005 8:51 pm
Lordprimate
Postby Lordprimate » Tue Dec 20, 2005 10:36 am
Lordprimate
Postby eightvalver » Tue Dec 20, 2005 6:16 pm
Lance, that was some really really good information and explanation about what the settings do that I can use.
eightvalver
Postby Lordprimate » Mon Dec 26, 2005 9:17 pm
Lordprimate
Postby eightvalver » Tue Dec 27, 2005 9:37 pm
Yes, try the reflash.
The same thing almost happened to me.
What fixed it was switching the polarity of the wires for the IAC motor for both sides.
but I am still hunting for that magic number for consistent operation. I think the newer embedded code releases should solve some of the inconsistent problems.
keep us posted.
eightvalver
Postby Lordprimate » Fri Dec 30, 2005 8:04 pm
Lordprimate
Postby eightvalver » Fri Dec 30, 2005 8:36 pm
switch the polarity of the wires for the IAC motor for both sides.
eightvalver
Postby eightvalver » Fri Dec 30, 2005 11:26 pm
try different start values
eightvalver
Postby Lordprimate » Thu Jan 05, 2006 12:25 pm
MS-II Blue V3 PCB
MT 2.25 Final Release w/ MS2/Extra 2.0.1 Firmware
In a 1.9L 93 Saturn SC2 w/ GM DIS.....
http://www.cardomain.com/ride/741154
Lordprimate
Postby Lordprimate » Thu Feb 09, 2006 3:46 pm
MS-II Blue V3 PCB
Lordprimate
Postby Lordprimate » Sat Feb 11, 2006 7:28 pm
MS-II Blue V3 PCB
Lordprimate
Return to General, New users, Purchasing
Users browsing this forum: BigBlockMopar and 1 guest
