Another neub here, first post. I will be installing a MS-II on a JDM EJ Subaru engine.
My first question: has anyone figure out the operation of the Subaru IAC valve? It's a 3-wire hook up, so at this point I'm guessing it's some kind of PWM valve? It also appears to be a type of rotary valve, as opposed to poppet operation. Is there any way to perform a simple bench test of the valve to see how it operates - without the Megasquirt?
I'm trying to decide whether to keep the OEM valve, which looks pretty sophisticated even having a water line hook-up - though it's bulky and ugly and uses a huge air line - like 3/4" or so(!), or switching to a "known quantity" in terms of MS use, like the Jeep stepper valve. The main intent of the vehicle is a Sunny day driver, but I want the engine to operate down to about 45-50F. The water heated IAC valve seems a bit overkill for this purpose. My thinking is if I use the Jeep valve instead and mount it to the engine block, that should provide enough heat to prevent icing?
Any advise appreciated!
Jeff
Subaru and IAC
Well, after thinking this through a bit more I think I will just adapt the Jeep stepper motor. Should be easier to hook up and get operational than the OEM valve.
On a good note I did some temperature/resistance testing of the OEM water temp sensor - the readings are identical to the Bosch sensors, so this saves from trying to adapt the much larger GM sensor to the 12 x 1.5mm opening. Just have to come up with an additional sensor mount for the dash gauge. Not sure what sensor mounting is used by Autometer?
Jeff
Jeff
JDM Idle working with PWM
I have the JDM idle valve working with one side (closed side) going through a 20ohm resistor to ground and the other side going to the FIDLE pin. The MS-Extra code is able to keep a fairly solid idle with closed loop control.
Porsche 914 w/ JDM Subaru 2.0TT converted to Single Turbo. Megasquirt II/v2.2 with EDIS.
