HELLO !
Is there anyone out there who has any figures of flow rate in the injector of the following system:
Fitted to these cars:
Peugeot 309/405
Citroën BX
Years: around 1989 until 1992
System name:
Magneti Marelli G5S0, throttle body injection, around 90hp which differs a little between different countries.
The engine code is XU5M BDZ2
But it should be the same injector on all BDZ and BDY engines i think.
Anyone ?, otherwise i´ll have to "assume" how big it is annd correct req. fuel after that , not ideal...
There are NO markings or numbers on the injector...
flow rating magneti marelli monojet system.
Peugeot 309GR1990 XU9JAZ(4cyl 1.9litre) 10.8:1 CR with 60-2 VR wheel decoding ,V2.2 card, singel coil and dizzy spark ,360cc 0 280 150 431 injectors. Msns-E hi-res 10d2 and E85(Ethanol) in the gastank.
