Mech pump to E2000
Mech pump to E2000
I tried searching but am having trouble getting it to work.
I know a surge tank is an option but I was wondering if there were other options when converting from a carb that used a mechanical pump. I was wondering if the mechanical pump would keep up with the E2000 or if some type of resivor was needed. I saw the write-up on the early bronco site about a spin on filter, but was hoping for an easier solution.
The application is a 1984 Jeep 4.2 (inline 6cyl) running MPFI from a 93 4.0 at about 43psi.
Thanks. Brian
Thanks. Brian
Brian
The mechanical pump can keep up with the volume of fuel needed, but it can not provide the controlled higher pressure required by the injectors.
You will need to add an EFI fuel pump, a high pressure filter, and a pressure regulator. Look through the MS manual for more details. See my web page below for an example of a fuel pump install.
- MS/Extra Guru
Anyone have a good idea what a good volume is for a surge tank?
My car is mid-engine with front mounted fuel tank. The plan at this point is to gravity drain the main tank into a Canton fuel filter - then to a low pressure pump (Carter or Walboro) - then back to the engine compartment to a surge tank. The tank will supply my high pressure pump, through an in-line EFI filter and then to the fuel rail. After making the injector round, through the FPR then to a T back at the surge tank. The tank will bleed some fuel into the T fitting (self purge) through a restrictor orfice and travel with the main return line back to the main fuel tank.
I've got enough room to keep the surge tank and and EFI pump in a semi-separated compartment in the engine bay to control heat and have it vented to the outside.
I'd like to find a pre-fabricated surge tank for this if possible - any ideas? I've thought of using a 2nd Canton large remote fuel/oil filter housing (no filter inside) as the tank, but that seems pretty elaborate (and $$$) just for an empty tank.
Jeff
Jeff
Thanks for the tip bleoh.
I checked those out - might be OK for the minimal $$ approach? - not quite what I'm looking for though.
I do think I've found the near ideal candidate though:
http://www.cantonracingproducts.com/tan ... html#80250
#80-205
I may see about having Canton do a slightly modified version, with the side inlet moved down ~ 1". All the fittings are 3/8" pipe - looks very suitable for this purpose.
Group buy anyone?
Cheers, Jeff
#80-205
Group buy anyone?
Cheers, Jeff
I made my own surge tank out of two toyota power steering reservoirs and a 10" chunk of 3.5" pipe.
I cut the nasty welding (my first welding ever) off, and redid it, it was just too ugly, though it did seal.
Total cost was $6 for the MIG welding wire.
Ignore the supra BOV and the wastegate
The total volume is about .69 gallons, enough to run my injectors wide open for a good 2.5 minutes. Far larger then it really needs to be... I like overkill.
'89 Honda Prelude 2.0SI 4ws
'76 Triumph TR7 fhc, soon to have ITB's and MSnS-e
