What should I use, if anything, to lube the O-rings when installing injectors? Thanks.
Brian.
Injector O-ring lube
The standard is clear silicon dielectric grease. Sold everywhere and also called "tune-up grease". It is used for many things and should be in your kit. Use it on sparkplug boots to stop sticking, electrical sockets and connections to stop corrosion, rubber gaskets and seals, etc. without attacking the rubber, plastic or metal.
Hope that helps,
David
Hope that helps,
David
