MS 2 V3.0
Hi, I"ve got a G60 Corrado and it's already hooked up with a Idle Stablization Valve - which is known to be unreliable and prone to leaks. I'd like to hook up something that can get the car to idle at -10 degrees F and not leak. I will be soldering the board accordingly so I need to make this decision.
thanks,
antony
Best option for IAC??
I'm running a g60 turbo and use the std idle valve. I placed it between the manifold and the output of the ic. This way it doesn't matter if it leaks under boost.
If you're using the original setup then you will loose boost pressure. You can get conversion kits for this.
SFC
Posted by email.
SFC
Posted by email.
