I've just picked up a cheap set of Honda Blackbird TB's for my car conversion. However, I found a bit of damage to one of the components and just wondered if anyone on here can offer any advice. A pic of the TB's is attached.
The part I'm talking about is the located between the first and second runner from the left. It is the shiney silver housing held on with 3 screws. On the top of the housing there is a hose connection, plus something else which has snapped off. I'm guessing this is some kind of choke mechanism (there is also a choke cable attached near the base of this part) and I probably won't end up using it. But if anyone can tell me exactly what it might be I would really appreciate it.
Thanks for the reply. So do you use the thermostatic choke on your CBR bodies, if so, how is it connected? or do you just leave it disconnected? Thanks for the link BTW.
My Blackbird bodies have 43mm butterflies and 86mm centre spacing. Measured with an old rule so give/take 1mm.
