Moved Battery, got problems
Could moving the battery to the opposite end of the car -- and changing grounding points -- have an affect on performance of MegaSquirt? I'm using MSnS-Extra to control ignition on a version 2.2 board.
I made several changes to the car and now have a terrible miss and odd ignition problems. It just hit me that one of the changes was moving the battery from the engine compartment to the trunk. My ground strap for the battery runs to the body in the trunk, and then from a fender to the engine where the grounding strap originally terminated.
Could this new arrangement create some sort of ground-value separation that would adversely impact how MS does its thing?
"87 Mr2
'96 Rav4
'65 Econoline Pickup
'75 Super Beetle
All Turbo, all the time
Why? Because I can...
'96 Rav4
'75 Super Beetle
I assume this is a uni-body so frame grouning isn't an issue.
Did the original battery location ground to the body or the engine?
If it was to the engine do you have a good ground strap from the engine to the body?
If all else fails maybe you could run a dedicated ground from where you are grounding the trunk mounted battery up to where you are grounding your MS.
MS2 v3.0 MT2.25 controlling 6 high z injectors and ignition
Thanks. I'm just going to put the battery back in the stock location and see if the problem goes away. I will have to redo the battery terminal connections, but it should be the easiest test to see if the battery relocation is the problem.
"87 Mr2
'96 Rav4
'75 Super Beetle
'96 Rav4
'75 Super Beetle
Make sure that your ground in the relocated area is a good, clean, and solid connection to the chasis. Then make sure the original battery location is grounded just as well to the chasis.
I don't recommend running a ground all the way back to the original battery location.
1995 Ford Probe GT ~ Megasquirted & Boosted
275whp/242wtq @ 5.5psi ---- 317whp/287wtq @ 8.5psi
^^^ (thanks to MSnS-E and dyno tuning by me!)
2003 GSX1300R (Hayabusa)
Unless it's big enough to carry the full cranking load because if it's a better ground path, it will carry more load. My TR3's choke cable did this once, because the ground strap had gotten corroded. The choke cable would glow cherry red during engine cranking. the cranking was much slower than it should have been too. Oops!Fastest95PGT wrote:I don't recommend running a ground all the way back to the original battery location.
jib
Good judgment comes from experience.
And where does experience come from?
Experience comes from bad judgment.
. . . . . . . Mark Twain
As a test, I hooked a set of long jumper cables to the negative terminal of the battery and the stock ground location on the engine. It didn't help the problem, so I'm reasonably certain it's not the battery location.
Not sure what's going on. The car seems to run fine for the first few minutes, when it's cold, but when it warms up a bit it starts missing -- with the miss getting worse the warmer the car gets.
It's an apparently random miss on all four cylinders. Watching the AFR, you can see it jumping lean -- I'm assuming that's actually the result of unburned gasoline passing thru. The injectors were recently cleaned and I have listened to each one with a stethoscope and can hear them clicking away just fine.
I've already replaced the distributor cap, rotor, plug wires and plugs, without benefit. I've borrowed a spare coil & ignitor from a fellow MR2 owner and will swap them in tonight, although the basic resitance tests indicate mine are fine. Edit: they were. No help
I'm down to clutching at straws.....
By the way, the car's been running fine for over a year now on MS. I guess it's possible something is going amiss inside the case somewhere.
"87 Mr2
'96 Rav4
'75 Super Beetle
'96 Rav4
'75 Super Beetle
