Ignition setup 4cyl single coil.
Click here to enter
Contact a Forum Administrator
Toyshop.no
Post by Toyshop.no »
Setting up with this specs, and wonder. In the ignition setup, you can set the angle, and now it says 60 degrees. 4 cyl should be 90 degrees shold'nt it? Or 67.5 + 22.5 ?
KGB
Post by KGB »
It's referring to the trigger angle, so it depends on when your trigger is "on"...
