well, this weekend while we were out test driving, the edis trigger wheel fell off and the car stopped (expected) we welded the wheel back on exactly how it was (we matched the marks up), and now when i try to accelerate quickly, the rpm drop to 0. if i let off the gas though, everything comes back alive. what would cause this? i attached a small datalog of this.
any help is appreciated. thank you.
HELP! RPM drops to 0 if i accelerate quickly, was working b4
Car Info:Toyota Supra Turbo, I6, 24V, Turbocharged, Intercooled
MS Info (and other pertinent info): MSII v3.0, Code 2.35, MegaTune 2.25, EDIS-6, Zeitronix WB
i realigned and replaced the sensor today, but no luck. do i have to reset the edis module somehow after something like this happens? or maybe reload the code onto MS? could something have gone haywire with the Accel Enrichments?
thanks lance for the reply
edit: also, i notice that when i stab the throttle, the PW spikes way up to 14-16ms, which it didnt do before. does this sound like a code issue? im on code 2.35
