Have big trouble getting any spark at all. Running V3 extra, and using single coil setup.
The distributor gives a correct trigger signal. Injectors and fuelpump are triggered, but not the coil. The "Spark A" cable only gives a weak signal randomly, and not enough to trigger a spark. Have tried almost everything now, and starts to loose nerve control.....
If someone got a bright idea i would be thankful! Maybe we have a fault in our settings in Megatune? Anyone have a good working "basic" file for 2,0 - 4 cyl turbo engine, 250-270hp, Grey bosch injectors (230cc), O2 sensor, Map sensor.
Howard
Toyshop.no
Can someone please help!!!
