Hi guys, i am looking to convert a olds 455 to fuel injection. Because no one makes a port manifold that i can find, and i don't have the budget to convert a carb manifold, I am looking to TBI.
The 455 is not going to be a race engine, just a cruiser. Has anyone bought a holley throttle body and used it with megasquirt? i was thinking of the 4barrel projection throttle body with 65lb injectors.
Any thought? I havent found many TBI units with large enough injectors other than the holley units.
olds 455, tbi which throttle body?
I have the progressive 85LPH Holley TBI on an Olds 455. If you can find it get it, they work fine.
You just need to use a code with injector staging, or find one with the old 1:1 linkage.
There's also a few other choices for TBIs if you can't find a Holley.
Live in Hampton Roads Virginia? Then join Virginia-MSEFI! With RSS, Mail2Forum, 13 members & Blogging!
