I am using MS2.2 w/ EDIS. If someone has an table to offer, great, but i am not counting on it. I am running 155 KPA, not high boost. But i get it at 1800 RPM. My redline is 7500
I am tring to set up an igniton table for my engine. I was running the engine NA, but now boosted it. I went through an retard all the timing by a few degrees, but the car sputters at low rpms and high maps. But since i am now getting max air at 1800 RPM does that mean i need to make my advance table completly different.
What is the max amount of timing advance i should run? How about at idle?
What is the relationship in timing advance between low and high RPMs under full boost?
What is the relationship in timing advance between low and high RPMs in the lower maps?
I am sorry i am full of questions.
scott
Help, Boosted 4AGE
Heres the entire MSQ. It is for 021u3. From what I remember it was a jdm 4agze bottom end 8.9 to 1 compression and a big port tivs head with the tvis plate removed. It also had reground cams and the 440cc injectors. Turbo was a t3 super 60 compressor and a t3 stage 1 turbine with a 48 housing. Probally a good starting point for you but you will have to retune it im sure.
