The sensor, module, and coil pack are mounted. The plug wires are made. The wiring harness is complete. We hooked it up and tested it with the MS disconnected; it made spark.
I pulled the MS from my Bug and am in the process of doing the board mods and checking for problems with the board. (My little vise and the de-soldering bulb were great investments!)
After that, it appears to be a matter of setting MegaTune, getting it started, unplugging the SAW wire to check static timing, and tuning the ignition table.
Anything else I should worry about that's not necessarily in the documentation on megasquirt.sf.net?
EDIS install almost finished.
