Here is a standard config screen from the MS II site
I'm installing MS II V3.0 on a '73 Porsche 914 (4cyl, port injection, 4 injectors, low impedence injectors, speed density). My required fuel came out to be around 13.
Do I want 2 or 4 Injections per cycle?
What about injector staging? Alternating or Simultaneous?
Even fire or odd fire? (i say even fire according to MS II documentation)
I have my injector banks setup as follows, correct?
INJ1 - Cyl 1, 3
INJ2 - Cyl 2, 4
This is the firing order of the dizzy:
I plugged into the calculator here:
http://www.megasquirt.info/v22manual/mfuel.htm
Disp 122 cubic inch, 4 cyl, 4 inj, 4 squirts, 24 lbs/hr, alternating, gas.
That gave me Req Fuel of 13.3ms and downloaded req fuel of 6.7. This satisfies the required fuel range of 6-15ms. So are these settings acceptable?
Thanks!
MS II Constants? Injection Control
'72 914 2.0 MS tuning in progress
MS II V.3.0
MS II V.3.0
You may want to (not sure how) move this to the air/fuel section, this is ignition.
I'll try to answer you:
Do I want 2 or 4 Injections per cycle? On a stock motor with stock injectors you could probaly use either.
What about injector staging? Alternating or Simultaneous? See what works best. I am using simultaneous.
Even fire or odd fire? (i say even fire according to MS II documentation) This is not used for anything right now, so don't worry about it. I would bet it is even fire.
INJ1 - Cyl 1, 3
INJ2 - Cyl 2, 4
MS is batch fire so I don't think it means much. You can try different combinations to see if it changes how the engine runs.
INJ1 - Cyl 1, 3
INJ2 - Cyl 2, 4
MS2 v3.0 MT2.25 controlling 6 high z injectors and ignition
