Tach signal 1 cyl. 2 strok Vespa engine, setting MT to 1 cyl
Click here to enter
Contact a Forum Administrator
endicott
Post by endicott »
Tuned my car with MS and now my old Vespa GL from 1961 is the next victim.
Found a tach signal on the bloody 2 stroke, but it shows between 3000 and 4000 rpm during idle. And a slight rev shows even more!
I've set it MT up to 1 cyl. under "Settings-Injector Control-Number of Cylinders". But is that enough? Can't find any other place to edit the cylinder count!
Vincent
The Danish MS'er
endicott
Post by endicott »
Found the source to my problem to be MegaTune. It can't run in two stroke mode, runs it as if it were four stroke! counts one tach signal as a ½ crank turn. NO good when it's two stroke; one tach signal one crank turn!
Regards
Vincent
The Danish MS'er
