Please help!
Click here to enter
Contact a Forum Administrator
Toyshop.no
Please help!
Post by Toyshop.no »
Trying to start acar with MS. It started and ran 3 weeks ago, but VB921 burned. Got a new one, got spark again, but the car wont start. It has spark and fuel. Checked timing, and everything seems ok. BUT, i am not sure i got all settings like it should be. Tried many different things, but nothing seems to work.
Could someone please set up a "basic" file for me?
The engine is a 2,0l - 270hp(+/-) turbo engine (8v) 0,7bar
Gray bosch injectors (230cc ?)
We are using "hall sensor" and single coil. No knock sensor, no AFM, onbord map sensor.
Howard
whittlebeast
Post by whittlebeast »
Post your msq and see the red wording above :)
AW
emills24
Post by emills24 »
I am no expert but I had the same issue! Fried the VB921 replaced and zap same thing again, I found that I was fryin not only the VB's but the coil pack cracked, all because the dwell settings were incorrect causing the car to charge to long. Inserted the new #'s and bam the car started, still idled ruff needed tuning, all is well now.
Also check and make sure you have the correct channels fir the firing order set had mine backwards once :oops:
