Is there an off the shelf manifold or manifold assembly with plenum chamber that can be fitted to the Chevy SB that then gives you port injection i.e. 8 injectors next to inlet ports on the heads like my Rover V8 set up?
Its difficult to track down these sorts of things from the uk!
Cheers
Nev
Port Injection Manifold Chevy 350 UK
Re: Port Injection Manifold Chevy 350 UK
Check this page out, it gives the main off the shelf options for Gen I small blocks.
http://www.stealthram.com/intakecompare.html
I personally decided to convert an LT1 intake. You can buy them already converted (LT1intake.com) if you want off the shelf, of maybe save some money buy grabbing a used one (I think they average about $75 on eBay) and modifying it yourself. It's not a 100% bolt on, but it ain't rocket science either.
