I've got a 1.8 Zetec running GSXR 600 TB's and MS V2.2. Cars been running fine for about a week and been well behaved durung 5 2 hour plus mapping sessions.
The MS was fitted fopr me and the guy who did it has been helping mapping and using his Innovate LC-1. As I say the car has been great so far.
Today I got the car back from him to drive to my parents. We switche the wideband back to the standard ford Lambda sensor (narrow band). Took the car for a test drive for about an hour and everything was ok.
About 50 miles into the journey the car overfueled and ground to a holt slowlly but started fine and ran back to normal before doing the same. During the last mile it just cut out altogther, the engine will start and appears to be running fine but will only run for about 30secs before it cuts out again.
At the moment I can't hook up the pc cos the usb adapter I have doesn't work with MS, so until tomorrow when I can get another cable/pc I can't check settings.
Is there any reason the car would do this and what should I be looking for when I get the pc hooked up?
Was Running fine with WB Lambda now won't run?
