I've been trying to dig all the info I could on this and came up with enough that I'm hoping to sound semi-intelligent about the whole thing. I have a 1989 Nissan 240sx with a KA24E engine. It runs a 360-degree slit CAS wheel with 4 inner slits (one for each cylinder, cylinder one being larger than the others).
I've been trying to understand what wavelengths the MSII will accept. From my digging I take it will not decode 360 degree signal. Normal optical wavelengths the MSII will accept are a slot for each cylinder with a reset slot? While I know I can just fabricate a Crank Sensor (36-1 VR type or any of the others), I'm curious as to what the MSII can do with the stock CAS wheel, if anything.
So my questions are:
1) Will the MSII only accept a wavelength with 1 wave per cylinder?
2) Is it for certain that the new Router coming out in several months will have support for a CAS Wheel of this resolution (and be able to decode it)? I've heard rumors that it's supposed to but god help me I can't find anywhere that actually says that's on a todo list or planned.
Thank you for your patience with a noob on ignition systems.
Dual Optical CAS Wheel and my options
reply
I am certainly not an expert. I just got my car running and I'm trying to tune it. That said, why megasquirt II? Have you looked into Mega squirt and spark? I have an eclipse and I'm running a dual wheel. I have a four slot optical sensor on the cam and I believe a one slot on there too; maybe a two slot deal. Anyway, I am pretty sure MSnS-e will do what you want and it's cheaper.
karl
I
karl
I
I did the exact same distributor on a JDM SR20 motor. Well, the same sensor.
It's simple with MSnS-Extra on an MS-I chip. You don't even need the "wheel decoder" -
you use the INNER (4-tooth) ring, add a 12v pullup circuit with 1k resistor, and run this to your tach signal. Config MS for a 4-cylinder, obvoiusly.
Then, you must figure out how to trigger the stock coilpack, HOWEVER I recommend using something like an MSD-6a box and coil, because you can use the "FIDLE" output on the megasquirt attached to the white (points pickup) wire on an MSD. THen you are driving. This is a really reliable, simple recipe using the low-res sensor in your distributor, and I can put you in touch with the guy who drives it 80 miles daily, has been for months!
Let me know if you have further questions,
-scott
-scott
Squirted: it's easier to list the ones I haven't squirted. I need to do more motorcycle engines!
