Is it possible, with MSII, V 2.2 PCB, to run a 60-2 wheel or 58 tooth wheel instead of the 36-1 wheel? I'm in the process of gathering all the parts to switch over a BMW 2002 to FI and would like to know.
Thanks in advance!
EDIS Trigger Wheel Question
The problem with doing this is that ford edis can run independently of megasquirt. The 36-1 wheel pattern is read by the ford edis module first and not MS. Megasquirt only takes the modified signal from the EDIS module for engine speed. Unless you can figure out how to modify the 60-2 wheel signal to read 36-1 to the ford edis module, you are going to need to use a 36-1 wheel.
