Hi guys someone may have already had this problem im fitting the msns-extra029i and running spark and fuel but i have no fuel pump
the old mk1 coil wires i have left are black 12v switched and red-black no voltage i guessing i need these connecting somewhere to get my fuel pump to work yes or no
i havnt touched any other wires to the pump so it must be these to any advice as to how i can get round this
cheers
Ben
VW GOLF GTI CAB 20VT ENGINE HELP NEEDED
I ran a new relay for the Fuel Pump and just plugged the connector where the relay used to sit (it`s quite lage I had to make an adaptor), on mine I believe yellow/red into the fusebox controls the VW fuel pump relay so I`ll be wiring that up eventually (I think output to the pump is also yellow/red to make things even more dificult..).
Squirted VW GTI 16vG60 mk2
