Idle issues
Idle issues
Rough idle(800-1300rpm), might stall unless give it a little gas in neutral.
I have build a engine 1900cc, eaton M45 superchager, ic and megasquirt (fuel and spark) and my problem is my idle is 1500rpm if I lower it is jumping 800-1300rpm.
I have try to seek vacuum leeks and look in the fuel tabels for diffrents in the idle area but nothing.
http://www.scirocco53.net
MS-I/MSnS-E V3
MS-I/MSnS-E V3
Check your "EGO Sensor Authority" settings .
The EGO Sensor will cause ocillations if it is operating at low speeds and is
capable of making large changes to the AFR .
It should be set to operate only above ~1500 rpm ,
and the "authority" should be 5% to 3% .
Also , check your injector pulse width at idle ,
if it is less than 1.5 ms it may cause idle instability .
Let me know what you find .
...................Jim
'95 GM 4.3 Vortec V-6
Single Plane Intake w/ported GM Throttle Body
Ported Heads , stock roller cam retarded 8 degrees
MS-II 2.6 , V-3 board , MT 3.0
EDIS ignition , Innovate WB 02
250hp , 28mpg @60mph in a 2 ton wagon
Does the car have an idle screw? This may need to be adjusted. Also make sure you are tuning for the lowest MAP reading at idle, not a lean mixture. If the car has an idle control valve which you are not using it could be letting air through and giving you false readings - clamp it off. Why not post a datalog of your problem? It would make it easier for people to understand the problem.
www.conrod.co.uk
20 valve turbo engine conversion, Mk2 Golf Gti
I remove the supercharger kit and the engine and idle works fine, and rebuildt the pipes for the superchager and mount a 2-wire VDO pwm valve.
http://www.msefi.com/viewtopic.php?t=19053
VW Scirocco 1900cc with Eaton supercharger 11psi in boost and E85 fuel (ethanol) 399cc injector
MSnS-E V3.0 code Extra 029q2 Edis4
www.scirocco53.net
www.scirocco53.net
hunt any vacum leaps you might have.
less ignition timing will product lower idle.
BMW, 1985, E30, 325i, 2-door, 5spd. Lots of custom work. Turbo build in progress: http://www.e30tech.com/forum/showthread.php?t=55733
Here is the datalog,
http://www.scirocco53.net/download/data ... 222017.xls
http://www.scirocco53.net/download/data ... 222021.xls
I have seek vacum leaks but nothing
MS-I/MSnS-E V3 029q2 code and PWM valve
www.scirocco53.net
www.scirocco53.net
No my charger have a boost valve, it is open when the engine is idle and on low load.
Giv me more clue!
/Per
Giv me more clue!
/Per
www.scirocco53.net
www.scirocco53.net
dude, i looked at your logs and 19-23 degrees timing at idle is way too much. you have to reduce that - ty 15, 12, 10, 8, 6 degrees untill you reach desired idling rpm.
