Im converting my 351 Cleveland to lpg injection (vapor) and have bought a compleet system from BIGAS. I have 8 solenoid like injectors with 4 ohms each. Do i need resistors for a MS2 versionboard 3. If so, what number of Ohm must i go for.
Update, i found out they are 6 volts so i gonna need resistors. A naibur calculated these injector draw 1.5 amps so i need 4 ohm 25 Watt resistor to get back to 6 volts.
Cheers everyone
using 4 ohm injectors
