I just found out that these injectors are 6VOLT, is it possible to drive them with Megasquirt??
Or do i need some kind of voltreducer.
This is for the moment a big BUMMER.....
Ho can i determen the amperage of thes injectors, just hooking 6 volt to them with a amp meter in between?
hey Pat, thanks for the reply, i over reacted a little to much.
I spoke a electrotechnic and he suggested a 4 Ohm 25 watt resistor to be on the save side to reduce the voltage and using pwm.
Im conserned on the spike of 12 volts these things can get trou MS so i gonna go for the resistors.
