After matching my trigger offset to my timing light my trigger angle came out to -10.5 (After TDC correct?) and seems to drift off when I increase RPM. This makes me think that I may have my spark output set incorrectly? The MS is controlling timing because if I manually turn off my bypass signal I can see a change in the timing.
MS II, on a Saturn GM DIS module.
A.J.
Negative Trigger Angle ?
1999 Saturn SC2 1.9L DOHC 4 cyl NA
MS II Blue Processor w/ 2.686t5 Beta Code
V3 PCB
MegaTune 2.25
Innovate LC1 WB O2 Sensor
OBD I Saturn Wasted Spark DIS
w/ Cooling Fan and IAC
V3 PCB
MegaTune 2.25
