1.8t vw trigger settings urgent please help
Hi got a 20vt engine running msns extra v3 board
i have the car running but its not happy to tick over and runs bad
im not 100% sure my trigger settings are correct i have
trigger angle 60deg
fixed angle-8 deg
A-5
A-14
B-35
B-44
its a wasted spark setup using the original coil on plugs
i dont have a timing light so doing this blind which isnt good but just need to confirm if the trigger settings are wrong will it run bad?? like mine
trigger angle 60deg
fixed angle-8 deg
A-5
A-14
B-35
B-44
Toss out what coils are connected to A and to B. The exact positions are going to vary some likely dependant on your positioning of the trigger. But I think your coils are setup wrong.
What should happen for examplew is coil A fires cyl 1 and 4, then coil B fires 2 and 3 180 degrees out. So in one revolution of the crank both coilpacks fire. In the first revolution its actualy firing 1 and then 3. In the next revolution it fires on cyl 4 and then 2.
Hopefully this helps you a little. It looks like your firing is coil A-A-B-B. You need A-B-A-B.
Forget the porn, my bathroom is full of car manuals...
1977 Rabbit (retired)
1991 Cabriolet (retired)
I also have 20vt engine, with wasted spark Passat V6 coils (2). I have same trigger setup, which seemed to work fine when cranking.
Now when i got it running, problem is wildly jumping advance. It jumps back and forth about 30 degrees, while its set to fixed 10 deg.
RPM seems to be ok in gauges and log-files, so no peaks or other errors.
I have MS1 v2.2 board and 29q2 firmware.
Try swapping the VR sensor leads?
