Piggyback / timing issue
Click here to enter
Contact a Forum Administrator
coyoteboy
Post by coyoteboy »
Having paused work on my daughterboard for the moment I was considering just going ahead with the piggyback idea for fueling for the time being. But then i struck a problem. I'm fitting it to a 3sgte which has a flapper AFM for fuelling (which i was obviously trying to remove). If I remove this will the stock ECU have no idea about engine load and thus not be able to set the timing correctly?
J
Jim
Post by Jim »
If you are retaining the ECU to control Ignition Timing ,
Yes ,
you must keep the Flapper in place .
You can still use MS with the Flapper in place but it does create some
air flow restriction .
...................Jim
'95 GM 4.3 Vortec V-6
Single Plane Intake w/ported GM Throttle Body
Ported Heads , stock roller cam retarded 8 degrees
MS-II 2.6 , V-3 board , MT 3.0
EDIS ignition , Innovate WB 02
250hp , 28mpg @60mph in a 2 ton wagon
coyoteboy
Post by coyoteboy »
Should have updated this thread really :) Sorry! Its running now, seems OK except its holding the idle open when the MS has the injectors for some reason. Thread if youre interested...:
http://msefi.com/viewtopic.php?p=119977#119977
