VW 16v ITB vacuum and ISV question...
I have a VW 1.8 16v engine with ITB and CIS at the moment, but i'm going to megasquirt.
My itb's didnt have a vacuum supply, so i drilled 4 holes in the manifold, one for each runner, between the throttle plates and the valves.
I've put some plugs in the holes, about 5mm, and attached a hose to them, which goes to a little "canister" from where the vacuum goes to the brakebooster.
The other side of the "canister" used to go to the ISV, but then i lost the brakebooster, as the other side of the isv went to "atmosphere" (manifold between the throttle plates and the CIS air meter)
I blocked this end with a hose and bolt, as seen on picture. ( goes under the "manifold")
When i'm converting to megasquirt, will the vacuum be sufficient for the MAP sensor, if i attach it to the "canister" and will i need the ISV for idle control? (And how should i attach it?)
I the first picture you can see the "canister" and the hoses, with the orange arrows.
The second picture shows the ITB's, the orange point is where i drilled the holes for the vacuum. Not on that point, but it will give you an idea. The holes and plugs are on the botttom as mounted.
I've seen pictures of the bike throttlebodies used, they appear to have a similar vacuum plug, but i didn't see anyone use this for the MAP sensor.
Greetings, soon to be a dutch megasquirter...
http://members.home.nl/schlappi/PICT002 ... 20view.jpg
http://members.home.nl/schlappi/motorke ... 20view.jpg
ditch the isv.
run the 4 map lines into one, and then if it pulses use a some sort of dampener, either fuelfiler+migtip combo or a carb dampener(possibly drilled out with 1mm drill bit if it dampens map too much).
If you still want to run a brake booster, tap one of the 4 manifold runners again for a feed to that.
However, after a year of different ITB setups on different motors I've given up on brake boosters and dropped them from my setups. I just don't get the same sort of assistance as per a single throttle manifold, and light car so why bother.
Tuning with alpha-n is insufficient if you're worried about any kind of emissions laws.keithmac wrote:You can`t run the ISV with that setup, it needs a common throttle plate to bypass. Canister should be fine for map input but most people on itb`s run alpha-n via the tps.
I'm working on testing some code that allows you to use two different maps and algorithms, and allows you to switch between them based on throttle position or MAP.
I'm going to be running Speed Density up to about 20-25% throttle position, and then alpha-n above that.
I was thinking about the 2 different maps, speed-density at low tps, and alpha-n at higher tps, but i didn't think it was possible... Keep me updated.
@Karl_Skewes: i still need the brakebooster, when i was using the isv it was really hard braking, i really need it.
Is it possible to check my vacuum? You can check it for pulses or for resolution i heard? Is there someone who can tell me how to do this?
Greets, Joris.
Greets, Joris.
ok, if you want to keep it, then simply tap one of the manifold runners for a feed for your brake booster.
Normally brake boosters have a bigger hose than map lines, that's why I do a separate tap of a bigger size for the booster.
You could probably get away with tapping 3 runners for map signal, and using one runner for the booster.
I hooked up a vacuum gauge today, when engine was idling the needle was pulsating, it kept bouncing between 80 and 40 kpa. (-0,2b and -0,6 b)
When i pushed the hose together it becam stable, 80 kpa at idle (-0,2b).
With just a little throttle it was 100 kpa (0b), and at decelleration it was 40 kpa (0,6b)
That doesn't sound right, does it? No load, just a little throttle, and right 100 kpa?
Greetz, Joris
Greetz, Joris
d***!
I did a cilinder leakage test (?) -> An adapter goes into the hole where the spark plug was, then you put air pressure on the piston (in TDC) to see if there's a leak. (Valves, piston rings or gasket...)
On cilinder 3: 10% leak. This is acceptable.
Then i measured the compression again, all cilinders good!
Now i found out my injector for cilinder 3 isn't working at idle, but works fine while cruising!
Could this be an issue for vacuum? I found out my vacuum is about 80 kpa while cruising.
What vacuum is normal on ITB's? Should it be 0 kpa at idle, and is it normal it drops to atm. very soon?
I have a 4-stroke engine, with other camshafts. I don't know what you mean by "radical" cams, i have the 2nd upgrade? We got 3 degrees of camshafts, sport, rally and race. I'll try to post the specs of the camshafts.
Can i built the megasquirt first, and then sort out my vacuum issues?
I'm now trying to sort out the issues first, but maybe i'll have to try to get the engine running on megasquirt first, and get my throttlebodies synchronized again.
Because of the bad injector i have to open the htrottleplates more for good idle, maybe they are opened to much for decent vacuum?
At idle my vacuum is about 80 kpa, when driving away it drops to atm., and when driving between 1000 and 3000 rpm it gets about 60 kpa, but a little more throttle and it drops to atm. again... At higher rpm it also drops to between 80kpa and atm.
At decelleration it gets 40 kpa...
My ride is a daily driver, but we don't have strict emmission rules here.. What about the combined alpha-n/speed density?
I find the time i'll post some pictures of the manifold with the vacuum plugs... (I have to get them off first..)
Thanks Mike_Robert, it's a bit clearer to me now...
Bit i need to mention i still need to build the megasquirt setup, it isn't complete yet. I almost have all the components, and will be starting the setup soon...
Another question, i couldn't find info on the difference between the normal alpha-n and the hybrid alpha-n. Do you know them?
If i'm cruising the vacuum comes back, so is it possible to switch between speed-density and alpha-n, depending on MAP and TPS signals? When driving, and having some vacuum, you would be using SD, and when the throttle opens, and MAP-vacuum is lost, you would be using alpha-n. This would mean while cruising the engine can be lean, and when WOT you're using alpha-n for power, disregarding the economy and emission.
Is there target AFR possible with the alpha-n?
Thanks, Joris.
Thanks, Joris.
