Hi all
need some advice on my fuel pump
the cars is a mk1 golf gti im using ms1 v3 board my problem is on my old setup the fuel pump took a feed from the coil which im guessing was a tach signal
i no longer have that coil or loom so how do i wire a new fule pump in ??
i have the main wire from the pump and a switched 12v that went to the coil but how do i get the pump to come on then go off until cranking
if anyone has any ideas id be greatful but please note wiring is not my strong point so i need an idiots guide
Golf gti fuel pump
