http://www.radioshack.com/sm-8-ohm-non- ... 62288.html
Other than being real ugly, any forseeable issue with these? I want to disable pwm with my 2ohm injectors.
8ohm 20w resistors from radio shack
Shawn,
How many injectors are you running? Many oems used resistor packs with multiple resistors in a single die-cast aluminum housing. Snip one off a mid-90's Honda, and you get a four resistors with a nice sealed connector as well.
Roger.
Roger.
1979 Mazda RX-7, running MSnSExtra hi-res 09c for fuel and spark control on a turbocharged, intercooled, and (of course!) injected 13B rotary.
