A couple of searches haven't fully answered my question... and all the new terminology has me a little muddled at the moment.
I want to convert a 1990 Chevrolet SB w/ GM TBI to distributorless so that I can relocate the engine further back in the chassis for better balance and front radiator clearance.
What MegaSquirt components do I need to add to do this? Or is there another aftermaket solution or GM parts bins stuff I can use to do this? Cost is a factor but so is PITA-factor.
I'm content with the GM EFI for now; the vehicle in question is not about ultimate engine performance. Packaging is more important at this point.
TIA!
Newbie Q on GM DIS
Thanks for the pointers.lance wrote:reece146,
At this point Ford's EDIS is a much more 'proven' conversion than the GM DIS. So this might make a better conversion (EDIS-8 is much more common than GM DIS for V8s as well).
If you want to experiment with GM's DIS, start here: http://www.megamanual.com/ms2/GM_DIS.htm and here: http://www.msefi.com/viewtopic.php?p=79435#79435 and here: http://www.msefi.com/viewtopic.php?t=4559
Lance.
My intent is KISS.
If I retrofit the Ford EDIS, is there a way for the GM TBI system to tell it when to advance/retard? Or am I committed to putting in a non-OEM ECU/CPU at that point?
I'm not adverse to that idea eventually, just would like a quick solution that doesn't rely on limp home mode for the ignition in the meantime while the rest of the car is being sorted.
Thanks.
Thanks.
I did stumble across this:
http://picasso.org/mjlj/
I dunno if anyone here has attempted to use this but it fits what I'm trying to do better (simpler, cheaper).
