ml to cc converstion?
I got some information on the stock 2002 GSX-R 750 injectors for a local Suzuki dealer.
The book states the Fuel Injectors are rated for:
168 ml (5.7oz) in 10 seconds at 43 psi.
How do you convert that to cc's?
It isn't as easy as 1 ml = 1 cc is it?
Bow
Re: ml to cc converstion?
Wow, I didn't think they would flow over 1000cc's a minute! What are some power and torque numbers for that bike?Bow wrote:... 2002 GSX-R 750 injectors ... 168 ml (5.7oz) in 10 seconds at 43 psi.
THANK YOU!PSIG wrote:Wow, I didn't think they would flow over 1000cc's a minute! What are some power and torque numbers for that bike?Bow wrote:... 2002 GSX-R 750 injectors ... 168 ml (5.7oz) in 10 seconds at 43 psi.
That is what I was thinking, I guess the injector cc rating isn't per hour... ;)
the 2002 Model in Stock trim is only like 114 hp...
So I guess they are 168cc injectors...
Thanks for the calm, cool and collected answers, and for not flaming the living hell out of me...
Too bad they are WAY too small for my 2.4 liter... now to find some that will fit in the Throttle bodies injector ports... say... 330cc?
Bow
Normally, it's lb/hr or cc/min, so those would be 1008 cc/min injectors. That may sound crazy, but it may have something to do with the high redline. Suzuki may be trying to do some sort of sequential injection there, in which case the injector doesn't have very long to be open.
So you are saying that I probably Could use these injectors on my KA24DE 2.4 liter with ITB's?Matt Cramer wrote:Normally, it's lb/hr or cc/min, so those would be 1008 cc/min injectors. That may sound crazy, but it may have something to do with the high redline. Suzuki may be trying to do some sort of sequential injection there, in which case the injector doesn't have very long to be open.
Bow
Uncle Bob,
That is not entirely true, RPM does have some impact.
Think of this, say your injector open time is 1ms.
Well, on a 5000 RPM engine, you have 12ms between burns, so that 1 ms lost to opening, isn't so significant only 8.5% lost to open time. You still have 11 ms.
Now a 13000 RPM bike motor only has 4.6 ms between burns, take 1ms off for open time and you are down to 3.6 ms, so 22% of the injectors time to spray is lost in open time.
I used supercharged Jaguar V8 injectors in my GSXR 750 throttle bodies, they are high impedance and flow 345cc min at 3 bar. The plastic cap on the very front of the injector is a bit bigger than the stock one and you will need to file it down a bit or drill out the hole in the throttle body to give clearance. The Jag uses a Ford engine and the injectors are marked Ford and Denso, I did not think to write down the part numbers as they were an ebay bargainBow wrote:THANK YOU!PSIG wrote:Wow, I didn't think they would flow over 1000cc's a minute! What are some power and torque numbers for that bike?Bow wrote:... 2002 GSX-R 750 injectors ... 168 ml (5.7oz) in 10 seconds at 43 psi.
Bodies with jag injectors
Pic from Ebay
Mark
I understand your point, but even in your example, that still leaves near 80%....plenty of time for a properly sized injector.LT401Vette wrote:Uncle Bob,
