Hey,
There was a brief post mentioning the 4age 24-20 dual wheel ignition.
Ie a 24 tooth wheel and a 4 tooth wheel.
I would like to use all the ignition features of the MS - its igniter and dwell control.
What is the simplest setup to use on an MS2 v3 with 2.5 or higher code with the Toyota setup? Additional outputs to control the blower, fan relays.
Can I just connect the second (4 tooth wheel) straight to megasquirt?
Thanks Everyone
Toyota 4agze 24-20 ignition setup (newbie question)
