Making cable for my 6 VB921 out triggers...
Click here to enter
Contact a Forum Administrator
Jon k
Post by Jon k »
I decided to desolder the DB9 setup I was going to use which entailed ~22 gauge wires from Leg 2 on the VB921 to the DB9 socket. I am now running 18 gauge wire from the output legs to a new 9 pin interlocking connector rated for 8 amps per pin. My question is, I have leg 3 of each VB921 grounding to pins 10 - 15 on the DB37. Should I desolder that and run 3 dedicated ground wires for the VB921s via the 3 remaining pins on my 9 pin interlocking connector? Or should I not worry about it?
