I have read carefully all the MSNSe ( http://megasquirt.sourceforge.net/extra ... wheel.html ) and i am still confused about how can Ms figure out a proper ignition timing with a 4/1 wheel using 2 sensor
Im really into the nissan scene where CKP/CMP sensors are optical unit running on 360/4 holes disk , since i want to run coil on plugs i know i have to add extra hardware on the ms and load the proper code form msnse
Basicly i would like to know if MS would decode my stock ckp/cmp or if i would have to make a wheel like this :
but i can't figure out how can MS can give an exact timing if there is only 4 slots on a disk. It anticipates when -10deg(or whatever timing it's supose to give a Xrpm and X load) is gonna come and just triggers the spark ?
Excuse my ignorance but i am kinda noob in this domain, i searched the whole ignition forum and haven't found much detailed how to on sequential COP so i am asking the question here
of course im talking of a MS1 with V3.0 board running msnse
Sequential Coil-on-plug Crank/Cam Pickups
If you have control over the d*** thing, Your not driving fast enough!
The code isn't designed to support the OEM 360 tooth wheel, so something like that picture is required. Yes the CPU calculates when to spark and it works.
How can it work ? do you know or could you explain please , not that i absolutely want to know why but it's for personnal knowledge
i studied in mecanics and we worked alot with ignition and injection and i wonder how can such a system work
Anyway , glad to know that i'll be able to get the result i was hoping for , thnx for the quick answer
Short answer: a computer, timers and some maths.
JAmes
JAmes
